For Sale 2001 Lexus LX470 155k $17,500 Ogden, UT (1 Viewer)
Year
2001
  1. LX470
Mileage
155500
Color
White
2001 Lexus LX470 w 155,000 miles. Going to buy a different vehicle.
We bought this as a daily driver for my wife back in June 2016 at 119k miles and right away took it to the shop for timing belt, water pump, etc (see details below). Also installed new tires, still tons of tread left. I bought it while living in Texas and moved to Utah Jan 2020. It has only been on the snowy roads 2-3 times out here. It also comes with Heatshield windshield visor, front door visors and a rear window visor. We have always kept it garaged. Rust areas were pressure washed, wire brush drill, wire brush by hand, rustoleum rust reformer/converter, rustoleum black paint and in October will get sprayed with fluid film.
$17,500.
Located in Ogden, Utah
Here are the big maintenance items we have done since we bought it. I have all receipts. Oil changes and tire rotations always done every 5k miles at the Toyota dealer.
In the last 1k miles we had an oil change and tires rotated at the local dealer.
153,401 (3/2020):
Valve Cover Gaskets ($521)
153,000 (10/2019):
Rear Brakes, TJM front bumper, passenger CV axle replaced, alignment, 7 pin connector, brake controller installed, inner and outer tie rods, wheel bearings, front brake pads, grease drive train ($2,708.09)
152,000 (1/2020):
New battery
132,387 (4/4/18):
Ironman springs, torsion bar, shocks, passenger front door lock actuator, alignment. ($1,300)
120,251 (6/2016):
Timing belt, water pump, hyd. Tension adjuster, thermostat, thermostat gasket, drive belt, camshaft seal, transfer case fluid change, front and rear differential fluid change, transmission drain and fill 3 times, replace spark plugs ($1,538.69)
120,000 (6/2020):
4 new Hankook ATM 265/75R16 tires at Discount Tire w certificates ($900)
Oil and Rotate tires every 5k.
119,000 (6/2016): purchased the LX470
Still available. Make a reasonable offer.
Who did the AHC removal and suspension kit install? Was it a complete removal?--or did they chop the lines and leave all the junk still up all over the place? I see the AHC reservoir is still present... :(
Looks like a decently clean truck though, otherwise. GLWTS.
