2000 Jetta-WTF???
Discussion in 'General Tech' started by baldboy, Feb 25, 2007.
Thread Status:
Not open for further replies.
  1. baldboy
    baldboy
    553
    30
    Jun 16, 2006
    Tulsa, OK
    So the girlfriend has a 2000 Volkswagen Jetta with 108,000 miles.
    EDIT: It is a 2.0 Liter Gasoline Engine....
    Background: Two months ago the temp. light comes on, I go to check the coolant and can't because it is a sealed system. Temp gauge doesn't look excessively high but the light is on.
    She took it to the dealer, they flushed, refilled, etc. and said the cooling system is fine now.
    Two weeks ago: I check her oil because she complains the motor is idling rough etc... Oil is black, and about a quart low. She says she had gone about 5000 miles since last change.
    Here is PROBLEM 1: When I went to add a quart (all I could do till we got back home) I noticed that the oil fill cap had milky white crap covering the inside.
    Does this indicate a blown head gasket?
    PROBLEM 2 and WTF for the day: Yesterday I changed the oil before a 200 mile (there and back) road trip. I filled it to the correct level. Today I check her oil level on a whim and it is almost 2 quarts low!
    There is no oil on the driveway and no smoke from the motor.
    Where did the oil go and why?
    Side note.... The fill cap had white milky substance again but not as much.
    If it is a head gasket what ballpark can I expect for a repair bill?
    Thanks
  2. cam75w/ls1
    cam75w/ls1
    258
    1
    Jan 23, 2007
    Texas, of course.
    I'm guessing somewhere between $900-$1200 for the head job w/ oem parts. That will get the timing belt replaced while your in there. The condensation in the cap is possibly water from the head gasket but, if you have alot of short drive cycles where the engine crosses the dewpoint temperature then it creates condensation from the moisture in the air. Usually it contaminates the oil w/ water as well. Have you checked the cooling system for oil contamination?
  3. baldboy
    baldboy
    553
    30
    Jun 16, 2006
    Tulsa, OK
    The cooling system is a "sealed" system.
    I cannot look at anything but the overflow container-and it is clean.
    BTW, she JUST had the timing belt replaced at 101,000.
    Thanks for the response.
    Any other help is appreciated.
  4. Okie_dave
    Okie_dave SILVER Star
    807
    16
    Jan 2, 2005
    Tulsa, OK
    Take it to Glen at Action Automotive in Stillwater. Talk to him about it. Tell him I sent you there. He is very knowledgable on all kinds of cars and will tell you like it is. Don't schedule anything, just drive it over sometime and tell them the problem. See what they say about it.
  5. theside00
    theside00
    1,677
    24
    Jan 13, 2005
    Torfab, Seattle WA
    i think all VWs have that milky substance in there. My sister has a 99 2 liter and it has the same. The engine uses some oil also. Think that is just what you get when you buy a volskwagen.
  6. baldboy
    baldboy
    553
    30
    Jun 16, 2006
    Tulsa, OK
    Thanks Dave.... I have been there once myself in the past and found them to be pretty good.
    Sorry I haven't gotten back to you on the axle.... I called, stopped by, and even left a note for the guy that (hopefully) has them in his garage, but am getting no response.
    I will see what AA says about the VW.
  7. Okie_dave
    807
    16
    Jan 2, 2005
    Tulsa, OK
    Talk to Glen and tell him I sent you. Describe the issues with him. He has troubleshot alot of stuff for me over the phone. Wish he wasn't 80 miles away.
    No hurry on the axle but I am interested if you can locate the guy.
    Green Country Cruisers is having a membership drive now. Check the GCC forum for info - $750 ARB prize!!!!
  8. cruisermedic
    cruisermedic
    111
    Nov 23, 2005
    munith, mi
    i had the same type of issue on my grand am. first time i saqw it i was freakin out. oils looked good when drained no foam in it and right color and coolant was always full and looked clean. i was beating my head and had it pressure checked. all was fine. well in the summer i noticed the stuff was gone. then in winter came back. well it ended up i had to replace engine cause i threw a rod. same thing happened with new engine. winter milky stuff on stick summer no milky stuff.
    i figure it is condensation on the oil fill tube its the same tube as the dip stick(dumb design in my opinion). the fill tube was way out in the open and was exposed to cold air flowing through. my stick had a big plastic ball on the end that would scrape the walls of the tube as you pulled it out. i bet if you can take that tube off clean it out put it back on and run it a bit.....recheck oil, i bet you dont find any of that stuff on it.
    any way just my .02 and i know it aint much consolation.
    steve
  9. cruisermedic
    cruisermedic
    111
    Nov 23, 2005
    munith, mi
    guess i didnt read all replys to well;)
  10. landtank
    landtank SILVER Star
    19,226
    1,491
    Mar 27, 2003
    Groveland MA
    I don't know squat about VWs but the first thing I always check on an engine that seems to drink oil is the PCV valve. I had one that rattled and still allowed oil past. If that is the case you should find residue inside the hose going to the intake.
    Good Luck
Thread Status:
