200 Series Height
Charlotte. NC
I couldn't find anything on my search regarding the height of the LC200 Series with a specific configuration so forgive me if there is a thread on there on this question.
I've recently installed a Prinsu rack on my LC200HE. I'm debating installing the OME BP51 and NITTO Ridgegrappler 285/70/18/E tires on as well. The one thing I need to confirm is the height of the actual vehicle. My work garage doesn't have a very tall height clearance so I would like to make sure the LC would fit in the garage before I add anything else (it is my DD). Curious if anyone has the OME BP51 with the NITTO Ridgegrappler tires 285/70/18/E and can tell me how tall their LC sits. Even better if you have the Prinsu rack.
@Eric Sarjeant is your expert here . As for tires, lookup the spec diameter of your current tire vs the tire that you want. Find the difference and divide by two (radius) for net height difference.
You're in luck - look at post 1 in this thread. My 16 was setup with BP51s and 285/70/18 RGs here and the weatherstripping is at 83" and garage entrance is 84".
Your truck looks good with the Prinsu rack. I have theexact same truck and am just starting with Prinsu and lift. I'll be watching to see what you end up at.
Is the Prinsu quieter than stock rails and Yakima basket? Thanks
Thanks @TeCKis300 and @mcgaskins For the responses. That’s perfect and what I needed.
@163bc I’ve only driven it locally so far. It’s a little bit more wind noise but nothing intolerable imo. I think if I add some weatherstripping in between the wind deflector and the top of the car, it might help it a little more. One thing I have noticed that’s a little off is when I slow down around 30-40 mph, I feel a little vibration in the pedals. Still need to do a little more research on this. Not sure if others have experienced that with this rack.
