20% off lift kits and FREE LED lights going now
Texas
We just got our 06 gx470. As phase one for our “Charlotte“ we were going to do a 2” lift. Is replacing the UCAs required with this kit?
Newberg Oregon
Can you explain more about the details regarding the free LED lights?
If you purchase a suspension kit you get a free set of Led Side Shooter lights at a value of $198.00 for the pair. I posted the link below to the lights for you.
Newberg Oregon
With a 2 inch lift, it is not necessary to upgrade your UCA's. But, I do recommend that you replace them. Anytime that you lift your vehicle you're mathematically changing the way the vehicle is set up. Your caster alignment will be a little off, our upper control arms have a built-in 4-degree caster in the UCA's. This will bring you back to factory specs. so that will reduce the wear on your upper ball joint. The UCA's also use the factory ball joint, so if you ever have to replace the ball joint you can go to your local parts store or dealership and give them your year make and model and use the factory ball joint. They are also an upgrade from your factory upper control arm. They are lighter, stronger and will give you better handling and stability of your vehicle since you put a lift on your vehicle. Also it gives you more clearance for bigger tires as well.
I hope this helps!
Texas
I hope this helps!
It does help! Now I feel confident that we were right to order the stage 2 gas suspension kit. We also grabbed the airbag delete kit. My husband wanted to call yesterday, asking after the pre-built struts, thinking perhaps we could postpone shipping the kit until you had those in stock, but yall are so lightning fast it already left your place for ours. 🚚
Newberg Oregon
We try to be the best out there in customer service!! You will really like your kit!
NJ
Can these lights be surface mounted? I am looking to install them inside my front bumper which has cut outs for 3x3 lights.
Western WA
When do you anticipate getting this kit back in stock?
Toyota 100 Series Land Cruiser/Lexus LX470 Foam Cell Pro 2" Suspension Kit - Stage 3
DRANGED
Moab
^ copy ^
I'm in a GX470 (and have had very good chat sessions with the team @ IM, thanks for taking my detailed and specific questions Miller!) and the site says out of stock. I've saved some pennies and should get a steering rack and CVs for when I do the swap. The FCP stage 2 kit is on my wish list and almost ready to go for it to have in wait b/c the 20% off is unprecedented pre-pandemic.
BUT out of stock...
*EDIT*
site says, " Expected back in stock Jul 15, 2020" :bounce2:
Florida!
@DRANGED - you should call them. I have a stage 3 on the way for my 06 GX. They will still take your money and ship as soon as they have it. I ordered on the 15th and it will arrive Monday the 6th.
Newberg Oregon
^ copy ^
BUT out of stock...
*EDIT*
The kit for you GX470 will also be back in stock on or around July 15th. I do believe you have air ride suspension also. so you will need an airbag delete kit if you have not already replaced your air ride suspension. Our sale will be going on until the end of July as well.
