2" receiver for SOF Bumper
sleeoffroad
Supporting Vendor
Did not want to hijack the Hanna bumper thread but wanted to post a picture of the new receiver that works with our bumpers.
It requires cutting a whole in the rear crossmeber and removal of the tire carrier winch plate.
This could also be used on our older bumpers, however you would have to cut the hole in the bumper as well. All new bumpers have the cutout already there, instead of the 4 holes like the earlier ones.
Thanks to CDan that did this kind of receiver some time ago and sharing the info. Thanks also to UncleBen for allowing us to cut up his 40th.
e9999
You want to do what...?
Moderator
US
nice
so what's happening exactly here?
is the 2" tube welded to the bumper or held by the 4 bolts in the rear and the braces in the front?
Trumansburg, New York
Nice Christo :cheers:
Looks like it would still let you have oem subtank too.
And I suppose that your fabricated receiver plate was a bit cheaper that the Lexus cast one :eek:
Brentbba
Former Golfer
OC, CA
Oh fine....now you do it! :flipoff2: Where were you six months ago? :mad:
Very nice looking Christo. :D
cruiserdan
SupportingVendor Emeritus
Moderator
Land Cruiser Heritage Museum broom closet
That should clear the sub just fine. The receiver tube on mine comes further forward than that, at the same level, and it clears my sub.
cruiserdan
Moderator
Christo mentioned in his original post that fitment requires cutting a hole in the rear crossmember.
His bumper already has the holes in it and you would use that as a template. You would then drill the 4 holes for the through bolts that attach the receiver tube flange to the bumper.
EDIT
I shoulda quoted you so my answer made sence......... ;p
sleeoffroad
Supporting Vendor
e9999 said:
nice
The receiver is one piece with the mounting flange. Cut the hole, insert, attach rear "legs" tighten down. Then drill 4 new holes. Remove receiver, install nut plates behind rear crossmember, reinstall receiver and bolt down.
e9999
Moderator
US
so you're not using the holes from the standard pintle hook pattern (3 3/8"x 1.75") then, from the looks of them?
cruiserdan
Moderator
concretejungle said:
gotcha ;p
So what would be the best method for making such a cut?
When I cut mine I used a combination of a hack saw, jig saw and angle grinder with a cut-off wheel. In my case I had to cut through BOTH the bumper and the cross member. Christo's bumper is tough...:rolleyes:
e9999
Moderator
US
how thick is the metal the SOR bumper is made of?
devo
Salida
Christo,
We need to work on the second swing out for a gas can and I'm sold.
devo
sleeoffroad
Supporting Vendor
devo said:
Christo,
devo
Not going to happen. You have an 80, install a 2nd gas tank and do it the right way. Why mess with jerry cans when you can have it on-board
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
