2 inch wheel spacers
Need help!!! 75 fj40 with 36 x 16.5 tires. passenger side rubes on high steer. I bought 2 inch spacers to fix the problem. What i have found is that the ome wheel studs are not long enough for the spacers. So i started putting longer wheel studs on the rear. when I got to the front discs i found that it is going to be a pain in the.... My question to the veterens out there is this ( What size spacers can i put on with out changing the OME wheel studs?
Thanks guys
I am new and I searched but did not find this topic exactly
Alabama
get the bolt on wheel spacers, that have the studs built into the spacers themselves.
spidertrax makes a set
Shelton CT
i run 1.25 inch spacer with 38.5-16-15 tire,never had a problem with tire rubbing on the high-steer arms or frame.i got my spacers from marlin crawler.
