2 Cut and turn questions
Formerly CO. Now Seattle
So I'm doing another cut and turn because I have taller springs and now my driveshaft angles are too steep and out of phase. The axle is already apart and I'll be doing all of the welding tomorrow. And I've read up a ton on the whole process (Chicago's thread was awesome). But I just have two questions.
1. Would you all take the third member out of the housing to weld the diff side perch? I don't want to weld my differential on the inside. I think that I'll be safe without taking it out but what do you guys think?
2. How far into the axle housing does the knuckle sleeve go? Because the axle has been cut and turned befor, I can't cut it right at the end. I'll have to move in a bit to cut the new groove and avoid the welds from the previous C&T.
Thanks for the info. I'll take pictures as I go and post them up soon.
1. You will be fine. I prefer that the third in in the housing personally
2. about 2" But there is no reason not to cut and turn it in the same place (or very similar)
Sounds like you're starting the new year off right!:popcorn:
Get us alot of pics!
Thanks. I'm stoked to leave it in the housing. It's sealed up all nice and I like that :). Yeah, gotta start the year off right indeed. Gittin' 'er done.
