Living in the Past
I think the 5 is the shaft diameter or some. 18 is anyway the teeth amount. So no change to speedo/odometer reading.
On the chart earlier in this thread it shows two different part number for a 6 drive gear and lists teeth on the drive worm gear as six. The drive gear is a worm gear that fits on the output shaft of the transfer case. The drive and driven gear have to match otherwise the driven nylon gear will be short lived. This is why Toyota puts both gear teeth count on each part. I could be wrong but been researching this for a while to see what I can come with using bigger tires and 3:70 diffs.
