I'm a bit stumped here and hoping someone can help me out.
My '75 was disassembled prior to my receipt, and I'm trying to lego this thing back together (with some tweaks along the way).
I confirmed my starter is good/working using a remote switch and/or screwdriver to jump the leads, however I cannot get the starter to turn over with my keyed ignition switch. I'm assuming I have a grounding issue somewhere, but haven't been able to solve it.
Picture 1: I have continuity of the BW wire from ignition switch all the way to the starter (white arrow). If I jump the lead (white arrow to green arrow) the starter turns over. The yellow arrow has continuity to the + side of the coil.
Picture 2: White arrow , BY wire, has continuity back to my start switch. No idea where this should go. Blue arrow, WB wire, no idea where that goes either.
Picture 3: White arrow, BY? wire, connects to the + side of the coil. I can take another picture, but Pic 2 and Pic 3 wires all jump out of the loom together next to the coil.
Thoughts on my issue/where to connect the wires?
