As far as my research goes, you can build a stroker F engine by mating the bottom end from a 2F and the top end from a 3F. I have both engines and was contemplating building a 2.5F engine with an RV cam and MAF internals, but i have some doubts, the first being will it run too hot because of the upped compression? (our gas is 95 octane and thats the lowest, 98 highest) and the second doubt is valve clearance because of the upped compression. I hope to end up with a highly built motor that works well in hot conditions at the end for dune-ing and high rpm for climbing steep sand grades.
P.S. - No 2FE as we never got the 3FE out here in sand land, only carby versions of both engines.
