2.5 Lift + Spacers + OME Yellow Bushings CC?
SoCal
Caster with above setup and heavy load is -.4 PS and -.7 DS. Best option? I am angling toward Slee's 3* blue bushings, would that bring it back into spec, or close enough?
I'm having the same issue...and the front end wobbles a bit when I attach a trailer, not sure which fix to go with, but I love the lift kit.
2-4* degrees is spec, so even with slee blues you'll be under by a little. Plates are you next option, but would want to go back to stock bushings.
