cc93cruiser
CRUZAHEAD
As title states, this is my first ever mechanical breakdown in more than 2 decades of owning land cruisers of all series'. I have owned 40s-200's and have done plenty of preventative maintenance on all drivetrain components of all cruisers (diffs, t-cases, trannies, engines) but almost all work was preventative. Sure I have replaced wear and tear items such as starters, alternators, steering pumps, fuel pumps, head gaskets etc. But today at 302k miles, the 1fzfe quit on me . When I went to start one of my 80s this morning (1993 Land Cruiser), it started for a split second and then clack clack bump, engine turned off/died. Opened up the hood and right away smelled like unburned fuel.. Went to start again and starter rotates bottom end of engine with no abnorm noises, but will not fire up. I am 99% sure the timing chain failed or tensioner/s. I am going to unbolt 2 bolts that hold tensioner in place and see if I see a loose guide plate or ? Then most likely valve cover and then head if I confirm the culprit.. Do I have to pull the oil pan off to get oil pump cover/timing chain cover off? I am about to pull out fsm as its been awhile since I've wrenched on the 1fz. Just had quick question on the oil pan.. I am still in shock, but at 302k miles on a otherwise neglected 80 (from previous owners) that I bought at 284k, I am surprised it didn't go sooner.. Poor little engine that could, waited to surpass the 300k mark before it finally had a hick up. And of all places, in my driveway so I was not to get stranded! Now it's getting a new head gasket and the works...Any advice on timing chain/tensioners replacment?
