1KD-FTV failed injectors and cracked pistons
Serbia
Hello all, I have a 2010 LC150 1KD-FTV and just had a major failure while coming back from a trip. After towing it to the mechanic he diagnosed that the injectors were faulty, which caused 2 of the pistons to crack and that resulted in scoring of the cylinder walls (maybe there's something more but this is the most important info I remember from our quick call).
The same thing (I think) happened to the previous owner and the engine was rebuilt and rebored (it's in the service history and I am aware this was a known issue for earlier generations of 1KD). In that process, injectors weren't replaced but rebuilt and that's probably what caused this issue since that was done only 70k kms ago.
Due to the scoring, the engine will need to be rebored again and that's the main concern I have considering the car has "only" 310k kms. This is my first LC and I really liked it in this short period I owned it (it's otherwise in a great shape and Premium trim) and I planned to keep it for a long time but now I am concerned how this will impact the engine and whether I can rely on a car that had 2 major overhauls in such a short time.
So I guess my question is how screwed I am and if anyone has any similar experience to mine, and potentially any advice? :) It goes without a saying that I will use OEM parts, I am based in Europe and getting them (for a fair price) is not straightforward so also any hints where to look are valuable.
Thanks a lot!
^So it ran lean, then hot, then cracked the piston, or other? Just trying to understand the failure root cause.
Weak pistons, blocked injectors do not spray a good pattern, localised hot-spotting on the piston.
FYI, 'lean' is not really a concept in diesel engines as they do not meter an air/fuel mixture. Also, diesel engines run hot when they run rich, not when there is an excess of air.
To the OP, I suggest you post this in the Diesel section as the GX460 is a petrol vehicle and people here will have no experience of your 1KD engine.
This Australian channel gives a lot of information and experience on the 1KD-FTV: https://www.youtube.com/@Fourby4Diesel
For getting OEM parts, I used Japanese suppliers, IMPEX (very slow) and Amayama (a bit more expensive).
A possible long term fix may be to address its two primary failure modes: mechanical piston fatigue and thermal over-fueling.
The single best long-term solution is to rebuild or replace the engine using ceramic-coated, updated-design pistons paired with Diamond-Like Carbon (DLC) coated fuel injectors.
The Piston Upgrade Options:
Do not reinstall early-generation factory Toyota pistons. There are two pretty good options depending on whether you want to purchase a new short block or rebuild the one you have:
  • Late-Model Genuine Toyota Pistons (2014+ Spec): If you purchase a brand-new genuine Toyota short block, it will automatically come with the post-2014 updated pistons. Toyota fixed the original design flaw by widening the crown area and changing the metal composition to resist thermal cracking.
  • Upgraded Aftermarket Pistons (e.g., Baileys Diesel or High Performance Diesels): If you are rebuilding your current block, use heavy-duty aftermarket pistons that feature ceramic-coated crowns and teflon-coated skirts. The ceramic coating acts as a thermal barrier, reflecting heat away from the piston crown and drastically lowering the risk of thermal cracking or melting from a faulty injector.
Considering the short block would probably need to be shipped either from Australia or Japan to Europe that would be a very pricey option although I like that solution the most since the engine was already rebored once so I don't like the idea of having a 2nd rebore on a car that I plan to keep for a long time. That is based on the info I found that you can do either 2 or 3 rebores max on an engine before it becomes too thin..
I'll try to dig up a little and see if I can find the short block somewhere closer, otherwise I'm left with getting the upgraded pistons and DLC injectors. Btw the info about pistons and injectors spec was very valuable, thanks!
  • Like
Reactions: r2m
