Hey guys I've got my hands on a 1997 1hz motor, will be rebuilding both the engines but I've done the research, the supposed turbo engine rebuild kit for the 1hz is half quality Chinese cheap crap. The bottom end isn't my issue (done the research an upgraded compression ring, combustion bowl insert and upgraded big end bearings), I need to find more out about the cylinder head, the gasket needs to be slightly thicker to allow for the extra compression, and the valve lash set so the valves are open for a little bit longer. I was wondering if there were any aftermarket valves, valve springs etc for a 1hz cylinder head.
Thanks
Thanks
