1HZ Timing Belt Removal as well as fuel injection pump
Ventura, California
Website
ardnez.com
After setting timing to BDC and removing timing belt can I remove the bolt in the camshaft drive gear(marked im red) holding the fuel injection pump without disrupting the BDC position or will it be disrupted if i just start removing it after the belt is off? Do i have to take any other steps?
Follow the steps in RM172E shop manual for the removal steps. I did when I removed/installed the injection pump for the 1PZ engine.
RM172E covers the 1PZ and 1HZ engines. I don't recall all the steps off the top of my head but what you have in red is not a bolt....it is a nut. I don't have a pic of it handy but this is from partsouq.
Make sure you get a new o-ring when doing this job for that specific nut.
yo, thank you so much, definitely helped, getting closer to it, did not anticipate all this work but here we are, learning, appreciate the guidance
