Been doing a bit of work and had engine bay open. Noticed a bit of coolant leaked out top of expansion tank. Went to lift it, and the tank is totally full!
I have not over-filled it when topping it up. I can certainly take it out and removed the excess so it back down to the right level.
I was driving it about 4 hrs ago but it's cooled down to about ambient now so excess coolant pushed out to the tank should have been drawn back to the radiator. I took the rad cap off and there was just a tiny bit of pressure. The top of the radiator is not filled right to the top but is fully covering the core.
When I drove the work on a hot day recently the temp got up to 86 C but the temp came down again back to 75 to 78 where it's meant to be.
Could it be a sign that the t-stat is not working correctly? Or that something is blocked up? What controls the backflow of coolant as the motor cools down?
Motor is about 7000 km off needing the t-belt and tensioner (and water pump) done again at 700 k km's. I do the t-stat as part of the job.
It's a 1hz non-turbo'd motor.
Thanks.
Thanks.
