1HZ Head bokt instructions and torque specs?
Florida
I promise I have searched Google and forums and just can't find the tightening sequence and torque specs. Called Cruiser Outfitters and they said they don't know either. It feels like the answer shoukd be easy to find but I have come up blank. Any help?
Lightly oil the threads and heads. Tighten them all in sequence to 51ft lbs. Mark the bolts with a line facing forward, and tighten first pass to 90*, then second pass another 90* . You start gritting your teeth and praying by the 2nd pass. If you have tightened them all correctly the lines will be pointing to the rear when complete.
Thanks so much. I finally did find this also.
