1HZ/H55F Question
Rant:
this is what i find funny...
you buy an exotic engine and tranny
you need parts but you want reasonable (read cheap). want cheap then go buy american, a 1HZ is not a cheap engine, a H55F is not a cheap tranny and the accessories are not cheap either...
you are playing a rich mans game now.
Still trying to get a starter that is reasonable - do you know of any reliable sources in OZ? Ebay or wrecking that you have used or know to be ok?
Dan,
I got up with the guy in billings that has the r151's for sale. Sound like it the same guy you got your 1hz and tranny from. He definitely doesn't know what he has/had.
Ihz parts acc. can be found for fairly cheap. I think ENS prices are out of hand they are right up there with Spancter. If you shop around long enough you can find good used parts/acc. for these engines.
Give cruiser parts a try I got a nice 1hz starter from them for around $200. alternator was about the same.
Hey wayne...did you ever get a chance to measure the r151 input shaft length for me?
nope but i still can. i got carried away with the renovating of the garage and completely forgot. sorry.
once the storm blows over i will take care of that...
no worries...I know how projects go. I just found three r151 that came from behing 1hz. The price is right some i'm most likely going to buy them. When you get a chance i still could use that input shaft length to determine if the adapters will work. No rush just stay warm.
You don't by chance have a split case that goes behing the r511? or just the little stubby input shaft and coupler that mate the two? The r151's I'm looking at don't have the tcase's with them.
so, what were the measurements for the R151?
Thanks Dan,
I sent that pic to the company making the adapter so hopefully they can tell me if its a match.
One question about your 151...Did it go into 5th gear. I've heard rumors that the mines used a block off plate for 5th to keep speed down. I looking at buying the one Heem has for sale. He's told me it won't go into 5th.
Do you mind if I ask what you sold yours for? pm me if you don't want to post it.
Matt
Normally it's just a plate blocking the high gears. Lift the cover plate and you should see it. Sometimes we found a workaround....
Thanks Dan,
Matt
