Hey All!
I just got my new to me 1990 HZJ73 home! Loving it!
One thing I'm into is figuring out ways to lower the dirty factor. I'm a firm believer that if we all do a little, it adds up to a lot....
Anyway, I've been searching for a while and haven't really found any solid answers, mostly conjecture, so I'll see if I get some traction here. As is, the truck has no smoke at start up or idle, and will give a little puff out of the back if you're really railing on it to get on the freeway or climb a steep grade, that's it.
My first thought is adding a diesel catalytic converter either by scavenging one from a wrecker or with a Magnaflow aftermarket one. I know, I know, no computer or air injection. But, if it helps, why not? I've heard some say it'll gum up the cat, others say you just have to make sure it's hot enough. There looks to be a little resonator under the right rocker, what about sticking one there and wrapping it with header wrap? Just a thought. It's pretty close to the manifold and should have plenty of heat. Anyone have any experience based on science, free of climate denier BS? I'd run a DPF if I could.
The second set of questions I have are on biodiesel and WVO. I posted in the Alternative Fuels section, didn't see much love. Years ago I nearly pulled the trigger on a 300TD with the intent of running WVO, so I'm up to speed on gist of grease cars.
How does a 1HZ do on biodiesel/WVO? It looks like the fuel pump is a little more finicky about fuel. Anyone have any experience? What percentage biodiesel can I get away with without replacing the fuel lines? (there is a source not too far from me). If I replaced all of the fuel lines, how does the fuel pump hold up to full BD?
I had dreamed of doing a WVO dual fuel set up in the future, but it's starting to look like it isn't the best idea... I don't want to risk compromising this AWESOME powerplant. Anyone have any experience with a 1HZ and WVO? Can I get away with a percentage?
I would be happy to be able to employ any combination of these things, or if it just isn't in the cards I'll just enjoy my 22mpg mechanical marvel and keep it healthy.
