EDIT: This turned into a 1HDT conversion, original plan was 1HZ
1989 BJ70LV-KR (Lhd, 3B2, H55F)
I've been considering this swap for a long time and have finally started reaching out to some members on here that sell 1HZs. My requirement is to get everything necessary to complete this swap in one go and understand everything that needs to be done before pulling the trigger. Anyway, I'm posting my thoughts and asking for everything I'm overlooking, missing, or mistaken about. I haven't found detailed enough write-ups on here about this swap, but if there are, please link.
Cooling System -
1. Radiator - should a 1HZ radiator be a direct fit?
2. Fan
3. Shroud
4. Hoses
Heater core/routing/related parts? (No clue on this, my 70 has no heater)
Intake -
1. Air cleaner
2. Air duct/hoses - My 3B has a fully "under-the-hood" intake, all diagrams and pics I've seen of the air 1hz cleaner box show intake routing going through the side of the engine bay seemingly for a raised intake. I don't have any desire to go to a raised intake, but curious if it's necessary
Do any changes to the throttle linkages need to be made?
Any sensor/wiring related tasks?
Transmission - (I will not be purchasing transmission/transfer case with the motor as I have a h55f I purchased new a year ago)
1. 1HZ input shaft *
2. new OEM clutch kit - any upgrades I should consider?
* Can I reuse the 3B bearing retainer?
* Are these year specific?
Do I need a 1HZ bell housing and this rear end plate 1135517011? I don't want to make or use any adapters, so I will get these parts if they are otherwise necessary.
Any relocating of the transmission & cross member, and any drive shaft mods?
Installation -
1. weld new motor mount brackets - I'm assuming
2. electrical plumbing**
** I exclusively use a wilson switch due to living in a warm place and rarely needing pre glow to start the engine, 1 crank and that's it. I would like to maintain this setup so are there any components I can remove from the 1HZ and are there any changes to the current ignition I would need to consider?
** Is fuel cutoff always electrical or are there vacuum switch examples? I would like to know this in the event that I purchase a 24v unit.
** Engine related components that require electricity are glow plugs, ac, starter, fuel cutoff, starter, alternator?
Accessories -
1. AC - I have ac already, any hose routing changes with a 1hz AC compressor
2. Power steering - I don't have this. All engines I've seen have power steering and I will buy one with power steering. Since I don't have power steering, what else is needed to make this work?
All info/comments/help is greatly appreciated. Aside from helping me I think this might create a good document for future use.
Cooling System -
2. Fan
3. Shroud
4. Hoses
Intake -
1. Air cleaner
Installation -
Accessories -
