This truck has had a slow oil leak since I got it home last August, didn't appear to be an issue before the long trip home from Vancouver, as the shop I had do some work on it didn't observe anything when they were doing some maintenance on it for me before the trip. I've been very slow to get around to diagnosing this, and just lived with the slow drip on my garage floor till now.
I had convinced myself it was the oil feed/return hardlines off the center section, as it's apparently a common issue on these trucks. I got under the truck today to have a closer look, and it appears that area is bone dry, along with the hot side, but the compressor side is coated in oil. There's really nothing above the turbo that could be a source that I can see, so I'm now thinking it's my actual turbo that's leaking. Pics 1 & 2 are from under the truck, of the oil feed/return hardline, and the compressor housing respectively, and #3 is from above of the compressor section.
Recently, I've also got some oil staining around the intake manifold/crossover pipe junction, which I fear supports my theory that the turbo is letting oil past. Pic #4 is of the oil on the intake manifold, there appears to be some oil under the manifold on the intake side of the engine as well.
So, what am I looking at here exactly? What has failed, and what do I need to do to fix it? Seal in the turbo? Rebuild/new turbo?
