I recently bought a 2003 LC 100 with a 1HD-FTE engine.
It has done 93,000 miles and has a partial service history - all the main service stamps from Toyota are in the service book but it is missing the intermediate (4500 mile) service stamps. One owner had it for the first 7 years and I suspect they will have done the intermediate service themselves. It seems to have been looked after – a lot of money spent on a custom made stainless exhaust and the timing belt replaced on time etc..
There are a few issues with the truck which occur when starting in the morning.
The engine starts on the turn of the key but is accompanied by a big puff of blue smoke. Not just a slight puff – I mean a cloud of the stuff. .. After a couple of seconds the exhaust is clear.
I have searched the forum and from what I've read this could be indicative of worn valve stem seals. My question is whether this is likely given that the truck has (supposedly) done only 93,000 miles. Could there be any other causes of the smoke? PCV valve keeps coming up in searches on the subject and I’ve seen the problem attributed to an injection pump diaphragm. Any ideas and suggestions would be appreciated before I spend money of the valve seals.
The second problem with the engine is that when starting from cold (12 degrees in the morning here) the engine doesn't idle very well. It tends to run a bit rough - it sounds a bit clattery and the revs are not constant. It seems to lurch. Once the engine is warm, it runs fine..
Do these symptoms point to anything obvious? I would like to get it running nicely and don't want to spend lots of money on the wrong diagnosis...
Any suggestions gratefully received. cheers.. Jim
