I have been struggling with idle to 1300 rpm roughness on my 1HDFTE LC100. On idle with AC clutch disengage I can go back and forth between D to N without any drop in idle rpm and engine is purring like a kitten. However, with the AC clutch engaged, idle RPM would go up to 900-925 when the gear is on N then drops to 800-825 and stays there when moved to D, engine would sound rough when this is going on, similar to what you would hear from one or two injectors going bad.
What could be the culprit? At first I was thinking about getting the all the brand new injectors verified again. However, I began to doubt it has anything to do with fueling upon realizing that with the AC clutch disengage everything are purring like it should be, engine would idle fantastically both on D or N, now perhaps the problem lies on vacuum leak from AC solenoid or something causing extra strain on the engine when AC clutch engage?
Fuel pump is new, all 6 injectors are new, all fuel pipes are new, compression has been verified, odo is 125000km. With diesel engine it’s either compression or fuel because there is no spark to consider, my truck is otherwise running fantastic with good fuel economy and plenty of power but something is not right between idle to 1300 rpm. Above that rpm everything is fantastic.
Please advise and thank you very much!!
