1HD-FT 80 series build
Might as well pull the manifold while the bolts are still fresh, also a good idea if its your first one, I did on my first attempt to make sure where any webbing might be located, done about a dozen now.
What size exhaust are you running? Mufflers or straight through?
Also curious on any intake mods you might have made (or future plans) to get the G turbo breathing, maybe along the lines of this thread
https://forum.ih8mud.com/diesel-tec...hz-1hd-t-1hd-ft-airbox-intake-mod-thread.html
Any more pics?
Might as well pull the manifold while the bolts are still fresh, also a good idea if its your first one, I did on my first attempt to make sure where any webbing might be located, done about a dozen now. What size exhaust are you running? Mufflers or straight through? Also curious on any intake mods you might have made (or future plans) to get the G turbo breathing, maybe along the lines of this thread https://forum.ih8mud.com/diesel-tech-24-volts-systems/731686-official-1hz-1hd-t-1hd-ft-airbox-intake-mod-thread.html Any more pics?
I'll upload more pics soon. Have to get them off the laptop and camera.
The exhaust is stock with a flow through muffler. The plan is to put in 3' pipe soon.
The intake is stock with a Toyota snorkel. Probably restrictive, but i do not have plans to change it at this time. Since i can get 20 psi of boost at 2300 rpm i am not worried at this time.
Cheers
Jan
Jan,
From the pics of the engine, it looks like you removed the ACSD. Where did you get the plate and O ring?
Nathan
G'Day Jan, Congrats on the great pictures looks better than new. I was wondering if when you did the rebuild and checked the oil pump tolerances if they show any wear at all. Seeing as they are running at idle/operating pressures a lot lower than the 2H motors do especially when the 2H pressure relief valve body is worn. The 1Hz and 1HDT always runs way cleaner oil [far less soot etc] than the old 2H for any comparable mileage. When changing the bearings on two 1HDT motors I noticed the sludge in bottom of the sumps were so much less than any 2H I had seen before. Regards
There was no wear whatsoever in the oil pump. But this engine was pretty much new to begin with, so I would not have expected any. When we opened it up the pink toyota marks were still on cam and crank…
The 2H I had turned oil black in minutes. On this one I'll do the first change (100 miles) on the weekend, but I expect it to be pretty clean.
cheers,
Jan
Jan,
Nathan
Got mine from John at Radd Cruisers
It came in a kit with the o-ring, plate and bolts
Well done Jan. Looks great. Time to put the trials of the past behind.
I have my pyros pre turbo on the 1HD-T and post turbo on the 13BT. The pre turbo pyro reacts much quicker. Whoever had my engine in Japan ran it with a pyro as it was already drilled and tapped.
Looking forward to your updates.
(g-Turbo and intercooler are on the list for my 80)
gb
Seriously, considering what you have been through recently, I'm very stoked that you have a phenomenal engine in there Jan.
:cheers:
Beautiful work too.
Hi Jan,
Wow, that motor looks great. Definitely I would like to hear more about the specific changes, tuning, and adjustments made to your injection pump. Other than not having an intercooler, I am going to run the Grunter Extreme also on my 1HD-FT in the 45.
:cheers:
Steve
Looks great! Glad to see you're having better luck this time around.
Hi Jan,
:cheers:
Steve
Hi Steve,
Graeme will tell you exactly how to have the pump adjusted. I did not do that myself, I gave the specs to my pump guy, as it needed lots of calibration for the new settings. I'll pm you.
cheers,
Jan
looks great!
regarding the drilling the manifold: there are some threads about that. I've done it on-truck, twice, no problems. running at idle while you drill will blow the flecks out, but
1) wear glasses
2) work quickly, that manifold heads towards 300 degrees
