- Location
- United States
Pulling my motor for a GM swap. I'd like to sell it all in swoop opposed to parting everything out. But will end up going down that road if there are no nibbles.
Asking $500 for everything, basically core value but it runs. 191,000 on the clock. It had a slight tick, or what Robbie called a knock under load. He spent close to 2 hours with the rig, but said he needed to dig deeper to figure out what was wrong. Oil pressure and temp are right where it should be. Never overheated to my knowledge. New belts, juiced aisin fan clutch, main seal on harmonic balancer, oil pump seal with screws, distributor cap, rotor seal and wires all done with last 10000 miles / 18 months. Most emissions equipment will go with it as well. Still a slight leak of oil somewhere, but I am moving on. Should be a good core if you want to rebuild or if you need a running motor to get you down the road. A/c compressor, alternator and power steering included. Extra eaton fan clutch, set of belts and used distributor from cdan (never installed) included.
No hoses, harNess or ecu included.
Transmission also for sale, Awhatever, from a 97 LX450. No problems with it as far as I could tell.
Local pickup only. Will have motor pulled by Saturday.
