A CNC head is only as good as the hand ported head it was modeled after. Do you know if this shop has any flow numbers for the before and after CNC porting? If it is a nice port job I bet they could sell a few outside of Qatar if they opted to.
UPDATE:
It's been a while guys. This is an update to the quest to reach 300+whp in my 1FZE without touching the crank.
The engine is still being worked on, I have still not used it since last time, unfortunately. The reason it took so long was that I had to get yet another set of cams custom ground this time with the same duration as the previous cam but with a tighter lobe separation, from 112 degrees to 108 degrees.
The second change is the most recent one which actually just got done today, and that is a CNC head port and polish, as opposed to the in house hand made port and polish.
I am hoping to get the picture of the powerband and some videos of the engine in use at the dunes, by the end of this week, and I hope I don't get any more delays.
I'm stoked and I can't wait to finally use it.
In Summary:
1. Tighter lobe cams (112-108)
2. CNC head port and polish.
3. Miscellaneous fixes such as the transfer case actuator not engaging 4WD , throttle cable lazy and stiff feel and the clutch pedal being to far and loose.
