@ToyotaIsLife did you guys do stiffer valve springs? It looks like there is some valve float at the end of the run.
All I know is that 5252 is the constant in all hp calc’s. Sharp eye....Yep, math doesn’t lie. And HP and torque always cross at 5252 on a dyno that reads ft/lbs and hp on the same scale. So saying they cross at 5500 is not correct. On that dyno graph it is no more than 255whp.
The dyno operator was very careful to frame the picture in such a way that the actual numbers in the bottom left corner are not in frame.
Not to be a damper on your spirits, but there is not 270whp on that dyno graph. That’s a 255hp run maybe.
I still think that is a solid improvement over what a stock GenII 1FZ would dyno. Even with a manual transmission it can’t be more than 170whp.
so while the number looks low you now have 50% more hp than you had stock!
IMHO (not sure if @scottryana is referring to something else) the wave in the power/torque at the end of the run indicates this - loss of control of the valvetrain due to insufficient spring pressure typicallyI would assume they are stiffer yes, I'll have to ask and get back to you, valve float? That's a new term for me.
Ah okay. I will have to discuss this with the garage. Good thing you guys brought that up.
@scottryana I wanted to bring one thing up, the tuner tried doing a run with open headers, He told me he saw an increase of 25 hp ?!, I mean I had a straight-through muffler(when it turned on), how did it have that much backpressure, maybe its an issue with it being an electronic muffler, the valve might be closed halfway that's a common issue with electronic mufflers here. But 25 HP is a huge again, I am going to have to get rid of the muffler at some point, it must be suffocating the engine.
25whp would be a huge gain for a muffler. I don't know if it would even be possible on a NA engine. I hope the tuner didn't oversell you something. 300whp would be very difficult I suspect.
here in qatar , I guarantee you 100% you will
not find a single family without a land cruiser whether that may be 80,100,200 series. We love them that much.
Can’t tell if that’s something rattling in the truck or detonation
