Hey! First of all thanks to this forum, great source of knowledge! I have a 1996 petrol 4.5l Auto. I love it and use it everyday for work. Its got a LPG conversion, when I bought it had classic rough idle and stuttering problem, I ran it mainly on LPG so only got round to fixing it this summer. Changed the O2 sensor (Mine only has 1) This immediatly solved the rough idle and lack of guts up to 3k revs. It always then had a slight issue once up to speed and you let off the accelerator it felt like being slighty pulled back, little loss of power 2 secs on 2 sec off. This would go one you put you foot down or slowed up...... I didnt mind this, however slowly the problem of the stuttering and rough idle has come back...... With vengance.
Now it regularly stalls on idle, splutters and stammers up to 3k revs when you pass this it drives fine. It also has erratic revs on idle, it goes up and down from 0 - 2k randomly..... Also when you drive slow if tried to rev up and pull through a slow maneuver..... Its go so bad I hate driving it
Do you think this could just be bad O2 sensor again? I couldn't find the exact one to buy so when it arrived the plug didnt match, I had to splice it to the old clip, also one of the wires (Blue & White) from the loom was joined with a another that runs off up into the engine bay, I cant see where it goes....... The sensor fitted into the exhaust ok. just the wires different.
So I am left wondering if I got the wrong sensor, or it failed..... The garage it was at the other day said they 'tested it' but im not convinced.....
It also had a split in the air intake pipe between the filter and engine, this I replaced but it made no difference. I have seen that a dirty or bad MAF sensor could be the problem..... I dont think I have one, i think this is a VAF? Could this be an issue?
Finally the exhaust is sounding pretty gurgly, when I first replaced the O2 sensor the bolts were seized so I had to remove the exhaust section from manifold to the CAT, I discovered that someone had rung the bolts previously on the connection to the manifold from the engine, this made it a total bitch to do and I dont think its sealed 100%.....
Thanks in advance for the help, my knowledge is limited and I know there maybe a few issues here.....
Cheers
Cheers
