1FZ-FE Fuel Economy (1 Viewer)
Darwin, NT
Hi,
I have a LC100 FZJ105 with a 1FZ-FE in 5 speed manual and 33s. Car is weighing in at 3200kg with all the gear in it. Engine has had complete rebuild 15,000km ago. Fuel consumption was 24L/100km Replaced injectors and fuel consumption is now 38L/100km. Ignition system is new and fuel system is new. Most of the engine bay has been replaced radiators etc. Electronics have NOT been touched.
9 days from now I will have a Link G4+ ECU and wide band O2 sensor installed and tuned in the hope of fixing the terrible economy.
When you replaced the injectors did you disconnect the battery to reset the ECU? Are the new injectors stock or larger than stock?
They are meant to be a stock replacement. Work carried out by a qualified mechanic. Not convinced they are the standard size. Pressuming ECU and O2 will fix a lot of the issues I am experiencing.
