Has anyone had this before? (I did search multiple threads and consensus is it can be idler pulleys, water pump and chain tensioner from what I understand)
Thanks!
Thanks!
Could be belts, at least some of the noise. Take your garden hose and while
the engine is idling, direct the water (without a spray nozzle) at the belts
while standing in front of the radiator. If the noise changes for a second or two then comes back, it's the belts.
New OEM belts properly adjusted (not too tight) seem to make less noise than some aftermarket belts.
My OEM belts are shot. Can confirm this went away off and on with new belts. I had made in USA Toyota belts that went very quickly compared to the OEM Japanese ones taken off.
How many miles does that equate to? I recently discovered I needed new belts so I ordered more. I thought I had a set but couldn't find them.How long do belts last? I have replaced mine 5.5 years ago with Toyota OEM from CDan
As you can see, @brockdeck replaced his belts and it fixed it.Having the exact same sound at start up. Did you find a fix?
forum.ih8mud.com
