1973Guppie
Supporting Vendor
- Joined
- Jan 31, 2003
- Threads
- 952
- Messages
- 10,214
- Location
- "the whale's vagina", CA
- Website
- www.noahsarkstlc.com
I bought a new project fj40, 72 body and a 76 2f engine. I am working on trying to get the car running. Today I drained the tank, new gas, changed oil, pulled funky carb that was on there and replaced with a 2f used cleaned up carb. I could not get it to start so I: set the timing mark on the flywheel with the marker. It looked like the disty was put in wrong, so I pulled it and put it back in so the rotor was pointing just forward of the #4 cylinder along with the timing mark lined up. I then adjusted the valves per the fsm. Still did not start. I checked that the carb is getting fuel, it is. I checked spark from the coil on the coil wire pulled off the cap and got good spark. I checked spark on the plugs and it was there but minimal.
I did notice that the disty that is in the block has 2 mounting holes and I think the po put the earlier disty in the block? I pulled a 76 2f disty I have in storage and noticed it has the one mounting hole along with the single mounting hole in the 2f block.
will using a 1f disty keep the engine from starting?
when I try to start the car, I turns over fine but I am getting major blowback through the carb and no ignition.
any help appreciated.
Noah
Noah
