Yep, like a few already said, get an AISIN fan bracket and replace it. If you are anywhere near timing belt being due, do that at the same time since you are most fo the way there already when replacing the bracket.
I am replacing my TB soon and am thinking the following list should be replaced in process, correct?
1. Timing Belt
2. Water Pump
3. Thermostat
4. Serp Belt
5. Fan Bracket
6. Fan Clutch
7. Idler Pulley
8. Tensioner Pulley
anything else that “you might as well do while you’re in there”?
How did this thread turn from a tech forum diagnosing a specific problem to general advice for TB services.
1. Timing Belt
2. Water Pump
3. Thermostat
4. Serp Belt
5. Fan Bracket
6. Fan Clutch
7. Idler Pulley
8. Tensioner Pulley
TIMING BELT COMPONENTS |
Timing Belt 13568-09070 |
Idler Sub-Assy, Timing Belt, NO.1 13505-0F010 |
Idler Sub-Assy, Timing Belt, NO.2 13503-0F010 |
Tensioner Assy, Chain, No.1; Tensioner Assy, Timing Belt 13540-50030 |
L & R Camshaft seal (2) (SEAL, OIL FOR CAMSHAFT SETTING) 90311-38065 |
Front Crank seal ( SEAL, FOR OIL PUMP) 90311-A0001 |
ACCESSORY DRIVE COMPONENTS |
Idler Pulley 16604-0F010 |
Serpentine belt 90916-02586 |
Serpentine Belt Tensioner Assy 16620-0W100 |
Fan Bracket replaces (16307-50012) 16307-0F010 |
Fan Clutch (Fluid Coupler-Fan) 16210-50102-optional |
Fan Clutch lock nuts (x4) 90029-07010- if worn |
WATERPUMP/RADIATOR/COOLING |
Water-pump & Gasket 16100-09201 |
Coolant FIPG Seal Packing 1282B 08826-00100 |
O Ring (For Water Inlet Housing); Ring, O(For Water Inlet). *119; Engine No.=3xxxxxx; Engine No.=5xxxxxx; Towing Package-With(North America,W(Engine Oil Cooler)),*145 96761-35035 |
Upper Radiator hose (HOSE, RADIATOR, NO.1) 16571-50150 |
Lower Radiator hose (HOSE, RADIATOR, NO.2) (From thermostat) 16572-50150 |
Hose, Water Bypass- Front 16261-50090 |
Thermostat 90916-03100 |
Thermostat gasket 16346-50010 |
Radiator Cap 16401-67150 |
Radiator- DENSO 221-3152 |
Gallons Toyota SLL 50/50 Coolant (3gal) |
HEATER T HOSES |
Hose, Heater Water, Outlet A 87245-6A180 |
Hose, Heater Water, Outlet B 87245-6A190 |
Hose, Rear Heater Water Outlet, C 99556-20155 |
Hose, Rear Heater Water Inlet, A(From Engine) 87245-6A800 |
Hose, Heater Water, Inlet B 87245-6A210 |
Hose, Heater Water, Inlet A 87245-6A220 |
T-Connector Connector, Heater Water Hose; Connector, Heater Water Hose, No.2; Pipe, Heater Water; Pipe, Heater Water Inlet, A; Pipe, Heater Water Inlet, C; Pipe, Heater Water Outlet, A; Pipe, Heater Water Outlet, C 87248-60460 |
ENGINE OIL COOLER LINES |
Oil cooler Return Hose (Hose Oil Cooler) 15777-50030 |
Inlet Hose Engine Oil Cooler (HOSE C, WATER BY-PASS, NO.5) 16282-50040 |
Water Bypass Hose Engine Oil Cooler (HOSE B, WATER BY-PASS, NO.4. (J) ) 16281-50030 |
can anyone here chime in if this sounds like its related to those 4 bolts that the blue part attaches to the fan clutch bracket?
