Hi There
I was working on the wheel column ( LC 1999 ) being loose by replacing the bolts and bushing all to a tight fit.
I realized the telescoping option is not longer working. I had previously disabled it to reduce load on the telescoping motor.
We did try to open the motor and cleaned it. But it weak and works little when you tap on it.
The Toyota Part # on the motor is : 89232-60022
The Denso part # is : 110800-0040 and maybe a 2J
Anyone was able to find a Denso replacement which would probably cheaper ?
