1999 Landcruiser fog lights
California
My factory fog lights stopping working and the bulbs and fuse are fine. I don't hear the relay click anymore. I would like to check the relay but I'm having a hard time locating it. I called the local dealer and they refuse to tell me and say it's best if they look at it. They charge $95/hour.
Any ideas?
Any ideas?
I will tell ya for only $75.00 an hour.. ;)
It is unlikely that it is the relay, but I guess its possible..If you are sure that it isnt the bulbs, then I would check the switch itself.
Are you running a higher wattage than stock (or a different brand) bulb in the fogs?
SINCITY100: Yes, my bulbs are fine and they are stock. I will try to check the switch. Thanks
subspd: I will look into these oem fog lights. Thanks.
stupid thought........but make sure your headlight high beams are not on :D
