After 9 years of reliability our amazon failed to start. we have techstream running and a second (running) amazon on hand for comparisons
This went from running perfectly to dead with no symptoms showing before failure
immobiliser light goes out when the key (we only have one) is put in the ignition,
engine turns over but not a hint of it firing
pulling a coil pack and checking for spark with a spare plug shows no spark
We haven't checked for petrol as we have an LPG conversion fitted with an emergency lpg start function (and as such can completely bypass the petrol system)
we did pull the EFI fuse and relay from the running one and swap them into the non runner with no change (although if I'm understanding right the immobiliser light going out rules out that fault)
Techstream connects to all ECU's except the immobiliser (although this may be because I have the wrong model selected, my next task is to try all the options on the running one and compare to the non-runner)
the only current codes showing on the engine ECU are for Oxygen Sensor Heaters (Bank1-sensor 1 & Bank2-sensor 1)
historic codes were P0120 & P1120 which both relate to throttle pedal position.
I have put a techstream event log on http://81.168.22.130/tse.zip
Its only a 10 second recording where the key was in 2nd position - turned to start (engine cranking) and then key released back to 2nd position
