It's a 1998. Not 97.07 maybe? How about a little more details. No nav meaning it doesn't have nav or nav isn't working?
Thanks Aaron. I'll give them a call if I get to that.I had a similar issue with mine, blower was stuck on for a bit, I pulled the fuse then nothing.... It was the temperature control unit. Very $$$. I found one used from TLS Auto in CA for $199. In fact they sent me the entire unit ( dash assy, controls etc). I dont know if this is your issue but if it is I would check with them as it is a $800-900 replacement OEM price
Thank you for this.Check for 12V and good ground at the blower motor-if it's ok replace the blower motor. If not, check for 12v at the blower resistor-if it's good, replace the blower resistor. If not, then your problem is control or power supply. The resistor should have a thicker wire for the power supply to the blower, and a thinner wire for the PWM signal from the HVAC control. There should be voltage on that one as well.
Thank you for this.
I have 14.2v into the resistor and 1.6 out.
I ordered a resistor. Internally inspecting it I don't see anything obvious, although the clear gel material is somewhat liquid like. From overheating?
I have the FSM for the 2002. It shows power into the blower relay on a white/red wire. If you are going to try to replace the control unitResistor didn't fix it.
The control unit is 88650-60400. Replacements are $615. None on eBay used.
There is 13v across the large blue/white wires going into the resistor. But 2ish coming out to blower. I'm thinking the control unit is not sending the correct voltage along that third thin wire to the resistor ?
I'd the control unit the next step? Ideas?
Thank you
