My '98 LC (~367K on it) just started this issue. It will intermittently have a tough time starting, happens about 50% of the time now. It cranks fine and fast, but will not fire up. It does not matter if cold or hot, if I just stopped the engine and tried to re-start, or if truck has been sitting overnight. Sometimes I will let it crank for like 7-8 seconds and no go and then stop, turn the key again and it fires right up. Once running, it runs mint with no issues.
I do not believe this to be an issue with the immobilizer as when I insert the key the CEL is on and the immobilizer security light turns off (and stays off during cranking). In addition, I made a jumper from contact F in the EFI relay spot to the battery and the issue is still present.
EFI fuse looks fine, not hot at all. I put in a 30A one just in case but that hasn't changed anything either.
I have not yet tested for spark/fuel yet, but figured I'd ask for other potential things to check in the meantime. I'm thinking it is fuel as I don't see/smell a big puff of unburnt fuel out the exhaust when it finally fires up.
I am guessing that there is some other bad connection within the fuse box that is causing this...
