1998 Land Cruiser Rough Idle
New Mexico
Hey guys, new to the forum here but have been browsing for years finding helpful information on cruisers. I have a 1998 Land Cruiser which currently has 256,xxx miles and has started having some issues. A while back I had done some work which included replacing the starter. I then replaced the fan clutch shortly after due to a wobble from the bearing and while I was in there decided to change the timing belt and water pump. This all has been done within the last 10k and recently it has not been running well and has a intermitant popping sound and hiss coming from the driver side of the intake manifold. I should also note I changed the intake manifold gasket when replacing the starter which lead me to believe they may have not been torqued properly so after retorquing the problem is still there. I scanned with my BlueDriver which provided the codes P0300, P0301, P0302, P0305 and P0307 although there was no CEL. All arr misfire codes for one bank except P0302. After replacing spark plugs which were overdue and checking coils I am still having the problem. At this point I am at a loss as to what could be causing the issue.
66kid​
Thanks for the update. I replaced my Thermostat and fixed a lot of my issue. my hoses are all old looking so I may replace those. You have any part #s for vacuum hoses?
66kid​
I just used some bulk fuel hose for testing so I do not have any part numbers of what I used, but I might be able to help you our depending on what you need.
