I have 1998 LC that I am ultimately trying to replace the AC compressor on. I evacuated the refrigerant and managed to get all three bolts out. The thing would not budge. Finally I found in the factory manual that the wheel, hub, spindle and axle have to be removed to get the compressor out. Found a good YouTube video for that, but I cannot get the spindle off!
I have removed the nuts from the upper and lower ball joints and jacked the thing up. That allowed the spindle to drop quite a bit, but I still need it to drop about another 1/4 inch to remove it from the lower ball joint. It is as if there is some sort of rubber gasket in the upper hole that is preventing the bolt from the upper ball joint from moving at all. Any suggestions?
Thanks!
Thanks!
