- Year
- 1997
- Vehicle Model
- 80 Series
- Location
- Carbondale, Colorado 81623 United States
- Mileage
- 307000
- Color
- Black
Time to let go of my 1997 Triple Locked FZJ80. This truck is located at my home in Carbondale, CO. I have a friend that will be able to show and let prospective customer test drive or let PPI's come to check it out as I have moved to SoCal. Along with all the work done stated below I just sank $8k into it at Toyota, so it still has a 4 year/4k mile warranty under it. I do not have pictures currently of the interior, I will get my friend to send me those as soon as possible. Thank you for reading and hope this can go to a MUD member.
PRICE: $14,750 OBO also possibly looking for 200 series (will obviously add cash).
-Motor and Trans replaced ~25k miles ago. Motor and trans that replaced had ~178k on it.
- 307,XXXk Miles on ODO
-Oil Pump
-Oil pump seal 3. Alternator belt idler pulley
-A/C Compressor belt idler pulley
-Cooling system thermostat and seal
-Toyota Blue fan clutch, Water Pump
-Front main engine seal seal
-Distributor O-ring 9. Distributor cap
-Distributor rotor wires
-Ignition harness/spark plug 12. Spark Plugs - Denso Iridium
-Oil Change - Mobile 1 full synthetic 5W 30W motor oil
-Oil filter (Toyota OEM) 15. All primary radiator hoses(Gates)
-Toyota OEM Red Cooling Fluid 17. Alternator belts(OEM)
-A/C Compressor belt(OEM)
-Air filter replaced(OEM)
-Both large vacuum hoses from valve cover to intake plenum
-Valve cover gasket and spark plug seals
-PHH replaced with silicon hose
-Starter replaced 24. Radiator replaced
-Bushings and tie rods replaced
-Front knuckle rebuild on both sides
-Leveling kit
-Full stereo upgrade 29. EGR valve replaced
Drivetrain and suspension: The following were either replaced, installed or are
components on this rig.
OME 2.5" springs Icon shocks
Rear Power Stop Drilled/slotted brake kit
K1156
Dobinsons Caster Bushing Kit (installed)
Has center diff lock switch Adjustable Panhard Rod Track Bar
(installed)
OME steering damper (installed) Front Differential Full Synthetic Royal
Purple Max Gear 75W-90W Rear Differential Full Synthetic Royal
Max Gear 75W-90W
Purple
Transfer Case Full Synthetic Royal Purple Max Gear 75W-90W
Bumpers, body protection and recovery gear
1. AOE front expedition bumper(installed)
CONS:
-Center Console top is off hinges
-Rear driver side window is off track, I fixed it before I left and must have not done it well enough. (Easy fix)
-Colorado Pinstripes
-C.E. light on due to o2 sensors being removed.
-Oil Pump
-Leveling kit
K1156
(installed)
Max Gear 75W-90W
Purple
CONS:
