- Location
- United States
SOLD
1997 Toyota Land Cruiser FZJ80 – $12,500. Lockers! 170,0XXK miles on engine, trans and t-case.
The vehicle itself has 308,000K miles but the engine, trans and t-case were removed and replaced
with 170K mile units out of a 1997 LX450 that had a tree fall on it. Interior and exterior in excellent condition. As you can see by the photos this is a very nicely optioned adventure base build rig.
Please read below the itemized work that has been recently done to get it to this stage. It has had
the PHH done and is detailed below. This is a fully baselined Land Cruiser. It runs great and just a
solid base build.
OME 2-1/2” SUSPENSION LIFT with Icon shocks
NO ACCIDENT HISTORY.
Has Toyota FRONT and REAR LOCKERS
VIN: JT3HJ85J8V0152099
SOLD
Rig is in Spicewood, Texas 78669
Archie @ 512-800-8869
Call or text but calls are best.
The following has been done at my shop over this past couple of months.
Motor/transmission/transfer case: Replaced with units with 165K miles on them.
The following parts were replaced to baseline this Land Cruiser – All parts OEM unless stated.
1. Oil Pump
2. Oil pump seal
3. Alternator belt idler pulley
4. A/C Compressor belt idler pulley
5. Cooling system thermostat and seal
6. Toyota Blue fan clutch
6. Water Pump
7. Front main engine seal
8. Distributor O-ring seal
9. Distributor cap
10. Distributor rotor
11. Ignition harness/spark plug wires
12. Spark Plugs – Denso Iridium
13. Oil Change - Mobile 1 full synthetic 5W-30W motor oil
14. Oil filter (Toyota OEM)
15. All primary radiator hoses(Gates)
16. Toyota OEM Red Cooling Fluid
17. Alternator belts(OEM)
18. A/C Compressor belt(OEM)
19. Air filter replaced(OEM)
20. Both large vacuum hoses from valve cover to intake plenum
21. Valve cover gasket and spark plug seals
22. PHH replaced with silicon hose
Drivetrain and suspension: The following were either replaced, installed or are components on
this rig.
OME 2.5” springs
Icon shocks
Rear Power Stop Drilled/slotted brake kit K1156
Dobinsons Caster Bushing Kit (installed)
Has center diff lock switch
Adjustable Panhard Rod Track Bar (installed)
OME steering damper (installed)
Front Differential Full Synthetic Royal Purple Max Gear 75W-90W
Rear Differential Full Synthetic Royal Purple Max Gear 75W-90W
Transfer Case Full Synthetic Royal Purple Max Gear 75W-90W
Bumpers, body protection and recovery gear
1. AOE front expedition bumper(installed)
Rubber/Tires
BFG’s 35X12.5R17LT
Alcoa 17” wheels
Body/Exterior
New windshield
Interior
New center console DBL cup holder on back end of console
Drivers seat butt foam replaced with OEM foam
Seats have no tears and all work properly
Dash pad is not cracked and in great condition
I do have the rear third row seats and yes, they are in great condition
Carpet in good condition
Steering wheel in excellent condition – no tears!
WHAT WORKS THAT NORMALLY DOESN'T:
All seats
ALL windows
AC and Heat
Sunroof
Cruise control
What doesn't work:
Antenna
Drivers side visor has gotten floppy
Before you ask:
I'm selling because I have decided that I only need one Land Cruiser FZJ80.
Does it have lockers – YES!
Do the lockers work – YES!
Does it have third row seats – Yes
How long have you owned it – 8 months.
Can I drive it home - You can drive it across the country.
Do you know of any car haulers – no but Uship is a great resource for finding car haulers.
Has the head gasket been replaced – no but the engine only has 170K miles.
Has the PHH been replaced – YES!
Is the steering wheel leather torn - No.
Is that the original paint - yes that is the original paint.
Does the sunroof leak - they all leak and have a drip pans that captures any water and drains it away. If a sunroof is dripping water, it's because one or all the drain hoses are plugged.
Do you accept PayPal? - yes for a deposit but the remainder must be paid in CASH.
Will you accept a trade? - No.
What's your lowest asking price? - I don't negotiate with anyone unless they have personally taken the time to see the vehicle.
Do you have a clear title? - Yes I have a clear title in my name.
Is it still for sale? - the minute I have a deposit this listing will show that and when it is sold it will be marked as SOLD.
SOLD
solid base build.
SOLD
1. Oil Pump
2. Oil pump seal
6. Water Pump
9. Distributor cap
this rig.
OME 2.5” springs
Icon shocks
Rubber/Tires
BFG’s 35X12.5R17LT
Alcoa 17” wheels
Body/Exterior
New windshield
Interior
All seats
ALL windows
AC and Heat
Sunroof
Cruise control
What doesn't work:
Antenna
Before you ask:
SOLD
