- Year
- 1997
- Vehicle Model
- 80 Series
- Location
- United States
1997 Toyota Land Cruiser FJ80 Clean title with 269,900 Miles.
Full-time four wheel drive, no lockers.
WeatherTech Floor mats. Marathon Seat covers, Made in Bozeman installed on driver and passenger seat.
Recent maintenance:
269,900 - New battery installed
252,000 - Repacked front wheel bearing at Ressler Motors
252,000 - New power steering pump and replaced P/S fluid at Ressler Motors
252,000 - New front pinion seal at Ressler Motors
252,000 - New motor oil pan seal at Ressler Motors
252,000 - Transmission fluid, both differentials and transfer case fluid changed at Ressler Motors
245,000 - New Brake Pads/Shims and resurfaced at Ressler Motors
239,000 - Replaced all three belts at Ressler Motors
230,000 - Front brake hoses at Alpha Omega
209,000 - Plugs and wires at Alpha Omega
208,000 - Valve cover gasket at Alpha Omega
177,000 - Clutch fan at Alpha Omega
- Oil changes have been performed on average around 3,000 to 5,000 miles. Last oil change was performed on 11/14/20, 269,900 Miles.
- It has always used a little oil in between oil changes, expect one quart every 3,000, It probably is leaking some of that but no oil on drive way, using 10w30, but when it had 5w30 it was using more oil. I have had it 9 years and it has always used oil.
- It needs a front windshield.
- Small amount of rust above the windshield
- Drivers seat back rest control works but the switch is broken.
- Tires are old and worn.
- Check Engine light comes on some times, non-Toyota brand O2 sensor and catalytic converter installed.
Asking Price is $7500.00 or best offer. ***Absolutely no trades*** Cash only and local pick up only.
Check out more photos at:
Recent maintenance:
Log into Facebook
Log into Facebook to start sharing and connecting with your friends, family, and people you know.
www.facebook.com
