1997 FZJ80 Shock question...
Discussion in '80-Series Tech' started by hkimsoft, Jul 19, 2005.
  1. hkimsoft
    hkimsoft
    147
    5
    Dec 29, 2003
    Last night, looking at the rig from behind, I noticed that left side of the rig seemed
    little lower than the right. So, I went under and checked to see if there were any
    leaks in shocks... no leaks... then I measured the length of each shock...
    hmmm, left rear shock has droped about half of an inch compared to the right.
    Will replacing shock correct the problem? do I need to replace coil springs too?
    I am not looking at the lift at this moment so OEM parts will do.
    Thanks in advance.
  2. cruiserdan
    cruiserdan SupportingVendor Emeritus Moderator
    22,720
    7,576
    Mar 27, 2003
    Land Cruiser Heritage Museum broom closet
    The shocks do not support the vehicle's weight. The cause of the lean is elsewhere.
  3. hkimsoft
    hkimsoft
    147
    5
    Dec 29, 2003
    Thanks for a quick reply. Where should I look other than springs and tires?
  4. Tools R Us
    Tools R Us
    23,743
    5,482
    Jul 20, 2004
    Chandler, AZ
    Has it been in an accident, is anything bent? Did it have a full tank of gas? Almost no cars sit perfectly level. Measure from the hub center to fender flare to determine the low corner/side, check it with a full tank and empty. To adjust OME makes trim packers that go on the top of the springs to level the truck.
  5. hobbes
    hobbes SILVER Star
    738
    206
    Feb 2, 2002
    Naples, FL
    Did you do a sharp right turn into the parking spot where you were looking at the back end of the truck? If so that can cause a lean, especially in older springs. It's not uncommon to see vehicles lean to the driver's side in any case. The extra consistant weight of the driver + controls tends to make things lean that way. OME springs have caused confusion over the years by being marked in different ways. Bottom line is the stiffer springs go on the drivers side (either right or left). In your case, if the vehicle has a bit of a lean when at rest, the only way I know to fix it is to go for new springs.
  6. hkimsoft
    hkimsoft
    147
    5
    Dec 29, 2003
    No accidents and no bents.. just a bit of a lean when at rest. I will closely measure what you have
    recommended... is replacing spring hard on LC? It's my first 80 ;)
  7. Tools R Us
    Tools R Us
    23,743
    5,482
    Jul 20, 2004
    Chandler, AZ
  8. hkimsoft
    hkimsoft
    147
    5
    Dec 29, 2003
    Thanks, this will serve my needs.
    PS. man-a-fre.com sells OEM parts?
  9. Tools R Us
    Tools R Us
    23,743
    5,482
    Jul 20, 2004
    Chandler, AZ
