- Location
- United States
I'm selling my LC. I bought a pickup truck and decided to only keep 1 vehicle.
I've owned the cruiser for about 5 years. It has taken me everywhere! It was my daily driver until recent.
My Landcruiser has approx. 287k miles. I run mobile 1 full synthetic oil. I mainly use nothing but oem toyota factory parts for any fixes.
Since I've owned it, I replaced @190k miles:
-DIEHARD GOLD Battery
-4 New Michelin LTX MS2's
-Toyota Starter
-Toyota AC Condensor and AC recharged.
-Front Birfields
-Front Wheel Bearings repacked
-Front axle rebuild kit (oem)
-Turned front rotors
-Replaced front brake pads (oem)
-Replaced all 4 shocks with Bilsteins.
-@211,000 miles I replaced the front and rear brake pads (oem)
-Replaced front Rotors (oem)
-Replaced all 4 shocks with new oem toyota shocks
-Replaced front wheel Bearings (oem)
-Tune up- replaced plugs/wires/distributor cap, and rotor/belts. Thermostat.(oem)
-Radiator flush. Replaced upper/mid/lower hoses.(oem)
-Replaced front drive shaft u-joints (oem)
-Replace valve cover gasket and oil tube seals (oem)
-Front/Rear axles, Transfer case, transmisssion drain and refill.
-EGR Valve and EGR Valve modulator (oem)
Has great heat and AC.
Over all, the vehicle is in ok shape with minor dings and scratches. There are a few spots with surface rust.
Last winter a deer ran into my side, taking out the drivers side fender flares. I have the busted up flares if you want them. Antenna doesn't work, trip odometer works off/on,exhaust shield rattles under the truck.
I normally check my oil every other week and sometimes have to add a quart of oil.
Brakes should be looked at because sometimes when you brake hard, it vibrates. Once in a while the brake pedal can has a slight soft feel to it also.
Check engine light on.
I've had the code checked out and it is an "EGR" code. ular Landcruiser. As I already stated....it doesn't affect the way the truck runs what so ever....not even the miles per gallon. "EGR" means "exhaust gas recirculating". Essentially it is for emmission purposes.
I feel I have been upfront with as much information that I can. I have no intentions of wasting your time, so please be considerate and don't waste mine.
This is an as-is sale.
I also have it listed on Craigslist.
Located in Minnesota.
Looking to get $3000.00 cash only.
http://minneapolis.craigslist.org/ank/cto/4682491928.html
-Toyota Starter
-Front Birfields
