- Location
- United States
1997 Land Cruiser – Unlocked – 181k - SOLD
Two-tone sand/grey, tan leather
Bought it in February, enjoyed it but then I found my ideal 100 for sale.
Clean slate for mods.
$7200 OBO - traded it in for 5700, after removing a lot of the valuable stuff.
Ups:
Checked out good at Phil’s Toy Store (An independent Toyota shop here in NC, does a fair amount of LC work)
Runs cool – maxed at 202 in traffic with 140 air temp (from ScanGauge) before I changed the fan clutch, now maxes in low-190’s under same conditions.
Landtank MAF (also have the old one)
AC blows cold
Springs / shocks are OEM with 50k
Aligned last month
Replaced fluids in diffs / TC / PSF with appropriate Redline products
ATF changed twice (no problems, long story)
New rear main seal, oil pump seal and o-ring, distributor, plugs, plug wires, accelerator cable, OEM air filter, PCV valve/grommet
Eclipse AVN 5510 NAV/DVD head unit
New Pioneer speakers in doors (stock grills)
DynaMat Extreme in all 4 doors
Changed engine oil with M1 High Mileage 10w40 last week
Doesn’t seem to burn oil
CDL switch and pin 7 mod
I replaced 3 of the seat belts due to wear and poor retraction (the new ones are grey).
Replaced the LEDs in the heater control- now they are visible in daytime
LED wide-angle mirror/turn signal from Muth
LED brake / running lights
Remote door lock / unlock
Wired to run two headrest DVD players – each with its own player (included)
Landtank auto-up on driver’s window
Seats have some cracks, but are in pretty good shape considering
Removed the bubbling wood trim
Ran BG Frigi-clean last month
Geolandar HT/S are fairly new
WeatherTech Hood Deflector and Ventshades
New battery (Energizer from Sam’s – works well)
New FIAMM “Freeway Blaster” horns
Installed a hood support rod
Dashboard cup holder
Downs:
Most important: "D" light is out.
Probably needs font axle PM, front diff oil had a grey tinge when I changed it, knuckle grease is plentiful and thick, no clicking.
I removed the roof rack (not the ribs) and the air deflector – no broken nutserts! – but there is a bead of JB weld protruding from each hole.
I was going to Durabak the back and the roof, and I removed all the emblems (the big name one was halfway off), some of the paint under them is scratched.
The new fan clutch is from NAPA (I didn’t read the whole thread before I bought it), and occasionally causes a little shimmy despite my best efforts. I think a new blue hub is called for.
3rd party belts are currently installed – I have a new set of Toyota on the shelf.
Occasional steering groan, haven’t tried Downy yet.
Dynabeads in the tires for the last 2 months – I don’t recommend them, they cause a wobble occasionally.
One of the tires is running with a plug – holds pressure.
Undercarriage is pretty dirty from running with a leaking oil pump
mastiffdude/97_Cruiser - Photobucket - Video and Image Hosting
Ups:
AC blows cold
Aligned last month
Downs:
