SOLD [SOLD] 1997 Collector's Edition - AZ, locked (1 Viewer)
Carefully maintained, numerous upgrades. 124,000 miles. Recently rebuilt front end with birfield repack. FACTORY LOCKERS!!!
This may be one of the cleanest, lowest miles, fully locked 80 series available. Minimal cosmetic wear and tear (some paint transfer on driver side rear door from the kids - see below for close up pic). Original motor runs very smooth, AC blows very cold even in Arizona summers.
OME suspension with J springs and Slee parts
Toyo AT II Open Country tires 35 x 12.5 R18
KMC Revolver wheels 18 x 9
4.88 gears (installed by Sierra Expeditions)
ARB Intensity LED lamps
Dual battery system (Slee Offroad) yellow and red-top Optimas
Rear 12V power plug
Headlight wiring harness (Slee Offroad)
Aftermarket sound with Pioneer NEX feating Apple CarPlay
Slee sliders
ARB front (with custom PIAA fog lamps mounted) and rear bumpers
Drilled rotors
Also included:
Aftermarket projector beam housings for headlight upgrade
Aftermarket parking light housings
Clean title in my name.
$29,500
Price drop: $22,500
Build thread link?
Luck is the operative word with any 80 over $15k.
Yes, I am looking at rigs under and over 15K. Why do you say luck though? If something is not represented right, it will be made right by the seller as always :)
Looks good. You should make sure to point out about the slee arms that are 1200 bucks. That's fixing castor the correct way!
Glws!
Given that the imported diesel hdj's with half the miles arent fetching $20k. i simply would find it "lucky" if someone out there is ready to pay $10k more for a gasser. I think the last low miler in this price range spent a few months here on mud before it settled down at less than half the price. more power to you if you find that needle in the haystack tho.....and again.... best of luck. :)
And as an example.. theres a similarly built one thats got a 45k mile SLEE redone/warranteed engine for sale for $15k on craigs right now. so headgasket already done and new shortblock and head. Half the price, 1/3 newer engine/ hg done /similar build.
