For Sale 1997 Built 80 Series, 3x locked (Tampa, FL)--$17K OBO (2 Viewers)
Up for sale is one awesome, well built, much enjoyed 80 series! If you want to overland, explore, camp, travel, bug-out or just simply look like a boss this rig is for you!!! It can be a street queen but please don't punish her like that, she deserves better than that. Only selling because I have a new project and need the driveway space/$$$ for the next project and already have another built rig.
Story:
I am the 4th owner of this expedition ready 80 series Land Cruiser and have service records (3in thick!) from all prior owners. She was kept mostly stock until the 3rd owner started modifications to improve off road capabilities. When I acquired her (Dec 2015) I took her a step further. I completed body repairs/paint (color swap from red to black), interior refresh, stereo/speaker upgrades, added a Slee rear bumper, Front Runner roof rack with tons of accessories, snorkel and much more... Has more LEDs and lights than anyone could possibly need and is a head turner everywhere it goes. She is triple locked and has been a blast to drive…runs great and will go anywhere!
*Camping, recovery gear, extra parts and additional accessories can go with it for a turn-key ready to explore vehicle but are not included in asking price. To be honest I don’t need any of it…I have another built rig loaded with gear and don’t need two of everything. I am willing to let it all go for a package deal.
Build Notes Below:
1997 Toyota Land Cruiser (Clean TX Title)
Upgrades & Modifications:
Engine & major maintenance:
· Original 4.5 L 1FZ-FE I6 @ 239K miles
· Cap, rotor and wires done fall 2009
· Crankshaft seal and oil pump replaced fall of 2009
· Valve cover gaskets replaced 2009
· Water pump replaced 2010
· Fuel filters replaced 2014
· New power steering pump (OReilly’s) and rebuilt Toyota steering box installed in Fall 2014. Also replaced
steering cooler with a Derale aftermarket and new Gates high pressure line
· New spark plugs April 2015.
· PHH replaced with silicon hose
· Firewall hoses replaced with Green Stripe hose
· Photoman smaller Alternator pulley
· Blue hub fan clutch with 20k CST fluid
· New thermostat and radiator flush, fuel system flush, new front U-joints Dec 16
· Starter replaced 2017 (OEM reman)
· New front O2 sensor summer 2017
· Oil/filter changes Dec 2017 (mobil 1 hi mileage 5w-30 full synthetic)
Electrical:
· Autozone Duralast platinum 65 AGM battery installed Dec2017
· Urban Land Cruisers heavy gauge replacement battery cables connected with military batt terminals
· Blue Sea 6 place aux fuse box with 60amp fuse
· 6 gauge wiring to cargo area for subwoofer amp. Fused with 100amp maxi fuse
· 12v charge line connected to 7 way trailer plug with auto reset breaker
· Trailer brake wiring connected with auto reset breaker also
· Modulite trailer light module. Carries signal on separate wiring from truck and battery
· 12 gauge wiring to Blue Sea 12V outlet x2 mounted to passenger side cargo
Transmission:
· Trans serviced April 2015 with new filter and fluid
Axles:
· Factory F/R locking diffs
· Diffs have fresh gear oil and hex head plugs 2015
· OEM front axle seals and front axle service April 2015
· NAPA Rear axle seals and bearing service Dec 2015
· U-joints replaced 2017
Lift/Suspension & Chassis:
· TJM progressive springs 2” Front Apr 2015
· OME 863 heavy springs rear 2017
· SOF-25mm Front Spring Spacer
· SOF-30mm Rear Spring Spacer
· XGS Gold shocks Apr 2015
· OME steering stabilizer and front/rear spring spacers installed April 2015.
· Yellow caster correction bushings
· LandCruiser Phil front sway bar disconnects
· Metal Tech sway bar drop brackets front/rear
· Tie rod and drag link ends replaced with 555 brand in 2012
Brakes:
· Stock, serviced as needed
Wheels & Tires:
· Stealth Custom Series F5’s in Matte Black x5
· 315/75/16 Goodyear Duratrac MT/R tires
Armor:
· Metal Tech large stinger front bumper
· Slee rear bumper w/optional receiver
· Outpost Offroad Sliders
Instrumentation:
· Scangauge mounted on top of steering column
Exterior Lighting Upgrades:
· Headlights (high) H1-Osram Night Breaker Unlimited 55W
· Headlights (low) H4-Osram Night Breaker Super White
· Slee upgraded Headlight Harness
· Innovative wiring harness Depo Adapter
· Parking Light-VLED 194_6_W_5K_N
· Front/Rear turn signal-VLED 1156_21_HV_A
· Flasher-Advanced Auto
· Side Marker Rear-VLED 194_HP_R
· Back up Light-VLED 1156_21_HO_5K
· Tail/Brake Light-VLED 1157_21_R
· Driving lights-Rigid D2-Driving pattern 50231
· Aux Back-up light-Rigid D2-Diffused pattern 5025
· Rock lights- Rigid D2-Wide pattern 50211
· Roof Rack LED Bar-Front Runner 40” Flood/Spot Combo
Exterior Mods:
· De-flared, mounting holes welded
· Body work/Paint/Rhino-lining roof/doors/fenders 2016
· Window tint
· Silver Rear Hatch emblems
· SoCal Frank rear antenna/light mounts on driver/passenger sides
o Aux Back-up lights mounted
· New windshield with OEM gasket installed April 2015
· Belt molding replaced for rear windows/doors (have parts for front doors but not replaced as of yet)
· Custom Satoshi style mesh grill with FJ60 emblem
· Depo clear headlamps/corners/turns
· Depo clear/red tail lamps
· Front Runner Slimline II Tall Roof Rack with:
o RTT mount kit
o Awning brackets
o Axe bracket
o Shovel brackets
o Ski, snowboard & fishing rod carrier
o Double jerry can holder & 2x Wavian Red 20L Jerry Cans
o Pro stainless steel camp table kit
· Trasharoo (Black) Spare Tire Trash Bag
· Weathertech Side Window Deflectors (missing from drivers side 2nd row…flew off crossing windy bridge in FL)
Interior Lighting Upgrades:
· LED Glow 4pc. White LED Interior Underdash Lighting Kit under front seats for front, 2nd row floor illumination
· OTRATTW Switches
· VLED 5K LEDs map light, shifter, glove box, dome x2
· Replacement visors from Lexus LS400
Stereo, Camera and Coms Upgrades:
· Pioneer AVH-4100NEX
o Sirius XM SXV300v1 Tuner Kit
o MiroBypass Parking Brake Switch Fully Automatic Video in motion
o Rerii USB/HDMI Flush mount dash panel
o Rerii USB/AUX Flush mount dash panel
· Kicker speakers in dash
· Pioneer TS-G1644R 6 1/2'” speakers in front doors
· Pioneer TS-G1645R 6 1/2'” speakers in front doors
· Infinity Kappa Perfect 12.1 12” Subwoofer
· Alpine MRP-M650/450 amplifier
· Complete sound deadening
o Sound Deadener Showdown products
§ CLD tiles
§ Mass Loaded Vinyl
§ Closed Cell Foam 1/8”
§ Extruded Butyl Rope
§ Hydrophobic Melamine Foam
· Alpine HCE-C212 Front-view Multi-view Camera
o Alpine KTX-C10LP License Plate Mounting Kit
· Alpine HCE-C125 Rear View Camera
· Uniden 520PROXL CB Radio
o Mounted on drivers side of console
o 4’ Firestik (F) IIFS Series Tunable Tip CB Antenna (Black FS4-B) mounted on rear bumper swing arm
Interior Upgrades:
· JDM Hand Throttle installed
· SOR Tuff Duck Seat Covers/Console Cover
· Center diff lock button installed along with Pin 7 mod
· WeatherTech FloorLiner for front/rear/cargo
· BH3D Printing
o 80 series Cup Holder Insert
o 80 Series Dash Bezel/Cell Phone Mount and Plug
o 80 Series/LX450 Single Cup Holder
o 80 Series/LX450 Double Cup Holder for Rear of Console
· Wit’s End
o 80 Series Fire Extinguisher Mount-Rt side
§ w/locking lid (not installed) & cargo liner
§ required seat track extensions are on hand but not installed
o 80 Series Lock Box-Mini w concealment liner
o 80 Series Console Liner- Upper
o Refuse Containment System-Main Unit Kit
o LandTank 80 Series Seat Extension Bracket Kit
· Fire extinguisher mount
o H3R Performance NB3000 quick release bracket (Extreme Duty)
· Fire extinguisher
o H3R Performance HG250B 2.5 lb. HalGuard Black Clean Agent Fire Extinguisher
· Trailer brake controller mount for a Tekonsha Prodigy and wiring in place
· Custom red anodized shift t-case shift knob
· Cocoon Innovations GRID-IT Sun Visor Organizer x2
· Re-upholstered headliner/pillars
· Hanna Quality Interior Racks (pair)
Recovery gear:
· ENGO 10K winch
o 100ft of TJM synthetic line
o Aluminum hawse fairlead
o Southeast Overland fairlead liner
o Rewired with new solenoids and added wireless controller and relocated solenoid box behind grill in
2016
· Estwing E45ASE Camper’s Axe, 26in
· Heavy jumper cables
· ARB snatch strap, tree saver strap, winch line weighted blanket
· High lift jack on rear bumper swing arm
· 2x Traction Boards
· ARB pulley
· 5x shackles
· Long handled breaker bar
Additional vehicle parts:
· Spare parts
o front inner long side axle
o good used birf
o stock tie rod
o stock rear lower control arm
o front spindle
Additional Accessories
· Tepui Autana Sky RTT with vestibule and floor extension
· ARB 2500 awning
· Awning extension free-standing room
· SoCal Frank Exhaust Manifold food warmer
· Service manual
· Electrical Wiring diagram
· Stealth Custom Series star lug nut socket
· Yoda Teq Ditch light brackets for side mirrors (not installed)
· 2x Rigid D2 LED pods for ditch lights (not installed)
Known problems
· Side mirror vibration
· Driver’s side side-mirror with 1x broken bolt
· Trip odometer doesn’t work
· Short in door speakers
· Occasional leak from rear hatch weather seal
· Tailpipe cut short from prior owner
o Result=slight increase in exhaust noise (improved with sound deadening)
· Occasional EGR code P0401
Truck is still available
Any interest in selling the seat covers and front/middle row weathertech mats separately?
SOLD!
