1997 40th Anniversary wheel size and offset
ca
Hello. I am having difficulty finding this info. What is the actual wheel size, primarily the offset (pos or neg) of a stock wheel for a 1997 40th anniversary? The aluminum wheel which I believe came stock with a 275 75 16. Thanks.
4.5" backspacing
I don't believe the wheels on the 40th are any different, so you can just search for stock FZJ specs. Those numbers are what I recalled, and confirmed with a search just now
Are you trying to find an aftermarket wheel with factory specs?
4.5" backspacing
This is a very good question. If you wouldn’t mind I am going to start a new thread directed at this question. Perhaps this is where I should’ve started. Thanks for The direction
