- Year
- 1996
- Vehicle Model
- 80 Series
- Location
- Asheville, North Carolina United States
- Mileage
- 297000
- Color
- Black
1996 triple locked FZJ80 Landcruiser on 37" BFG TKO's. (milage 297,000)
Awesome rig in great shape. Everything works well with many upgrades. Motor is strong and compression is good. New professionally done head gasket with decked head 290K. Asking $ 17,500 OBO.
-Slee off-road Short Bus front bumper
-White Knuckle Off Road Products: rock sliders
-Creeper Skidplate for trans/ transfer case
-4x4 labs rear bumper with full size spare and 3 jerry can carrier rack.
-Geared 5.29
- Factory E-lockers (with Slee rear guard)
-Nitro rear axles
-RCV front axles
-Tom Wood CV driveshafts
-3:1 (still in the box due to 5:29 is plenty!!
-High steer knuckles
- Smitty built winch (XR3C 9500)
-3" OME lift with Sleep radius arms
- Adjustable rear control arms with Delta pan hard riser bracket.
- New: front main seal, oil pump gasket and bolt, crank position sensor o-ring, power steering pump, Fuel filter, coolant hoses under plenum, vacuum hoses around plenum, thermostat pcv valve, valve cover gasket
-Amerex B385TS, 2.5lb Halotron I Class B C Fire Extinguisher
-Second aux battery charged with RedArc BCDC1225D in vehicle charger
- Krieger 2000 Watts Power Inverter 12V to 110V: feeding house style plugs
-Rear lighting under tail gate
-Auxiliary LED light bar mounted on front bumper.
-Factory roof rack
-also Yakima Roof rack with mega warrior basket
-ARB awning
-High lift jack
-Third Row seating
- High end Pioneer DVD player and stereo
More images to come in following posts
-Geared 5.29
-Nitro rear axles
-RCV front axles
-Factory roof rack
-ARB awning
-High lift jack
-Third Row seating
