Conditions:
Would Neutral Safety Switch cause starter to engage but not turn over?
Battery tested good 2 days ago, It's a 2 yr old Costco Interstate.
I did not have a multi-meter today to check battery, but AAA tried jumping with zero luck.
Wanted to check power wire to starter but no multimeter kept in truck.
What more should I have attempted?
- Recently hooked up 2nd battery with Blue Sea ACR (unhooked to rule out)
- Changed EFI Relay
- Has a Viper Remote Start and Alarm
- Changed out Fusible Links then changed back to Originals
- Changed Starter to Denso Reman
- Check coil plug - no corrosion
- Did not Check Neutral Safety Switch, but ran selector thru gears
- Starter Clicks but will not turn over
- Old Starter clicked the exact same as new Starter
- Tried jumping it with 2nd battery and a portable power pack. Starter still clicked
Overall the Denso/Toyota reman starters have been the most consistent quality of the ones that I have used, had apart. All of the others have been disappointing quality, poor and/or missing parts, etc.
